Sloppy clutch pedal on 1995 YJ 2.5
Payj95
Cary, nc
95 YJ, 2.5 engine. Sloppy clutch: fluid level is full, no leaks detected. Clutch gets mushy after driving a short distance but still shifts fine. Pump clutch 1-2 times and it's back to normal. Is master or slave bad? Does system need to be flushed, new fluid and bleed?
Sounds like you have air in the system. If the fluid is staying full then Id guess you have no leak. Flushing it out can never hurt but a good bleeding should correct things.
