Hey Folks, hoping to get some advice for my new-to-me YJ.
The issues began with not having a check engine light, no fuel pump prime and hard starts. Then low power, sputtering, back firing and stalling when driving.
Checking the forums, all issues pointed to the PCM, so I removed it, replaced the capacitors with new Panasonic 220uF 25V capacitors.
Now the fuel pump primes on RUN, the starter cranks, but the engine won't fire and I still don't have a check engine light.
I pulled the gauge cluster and checked all of the bulbs, even swapping the working seat-belt light to the check engine spot, just to be sure.
I pulled a spark-plug and have spark, and there is pressure at the fuel rail when checking the Schrader valve, though I haven't put a gauge on test pressure.
I checked the DOME fuse, it was fine, I checked the fuse slot with a volt meter and test light, both tested fine.
I tried swapping the ASD and Horn relays, the connections looked fine, but it made no difference.
I tried connecting an OBD 1 scanner, which says "no connection found"
I'm really hoping for some direction on what to look for next. Are there any other spots to check on the PCM, or anywhere else?
