1995 YJ 2.5 engine swap for 2000 TJ 2.5
Maximvs
Utah
I recently purchased my Jeep. It's a 1995 YJ 4 cylinder with a 2000 TJ 4 cylinder engine. The engine hesitates and looses power around 2000 RPM. I changed the TPS and the idle air control valve with no effect.
This is missing some troubleshooting. You need to check fuel pressures, vacuum. When were the battery/ground cables last changed, when were the plugs, wires, cap and rotor last changed? Do you have a check engine light? If you don't did you try to pull the codes using the key method?
Your post is a statement with no actual question, just the assumption that folks here will help you with the bare-bones amount of information you've supplied. This is probably why you've only had one reply in 6 days.
If you're going to own a 30-year-old Jeep, you need to be able to do some problem-solving and troubleshooting.
