engine runs but it's choppy. It has good vacuum but with all the vacuum and intake on it seems to stutter and lag at low rpm. I can rev it up high and it runs pretty good.
A few weird things:
I have a vacuum port open and if i plug it while it's idling it slows way down and almost dies. Is it not getting enough air? Is it a sensor? Map sensor reads good voltage. Same with tps.
Fuel pump doesnt work with key on but with engine running it has 30 psi at idle and increases to 40 when i rev it.
Exhaust pops and sputters at idle. Is the timing off?
I'm wondering if all this might be some sensor. Brand new intake manifold and air filter, throttle body is clean.
A few weird things:
