1990 YJ 4.2 sometimes sparks and runs some time not.
Jharp59
Oklahoma
1990 yj. Did a 4.2 nutter bypass, 2100 carb, new distributor cap, pickup. fires sometimes. I have driven it. Most no fire. I put a different ECM and it seems more sensitive to some issue with it sparking. When it runs it runs great. i cant see a crank position sensor anywhere. I bought Jeep with this problem. i have 12 volts to the coil and going to the distributor thru the coil wire to yop of distributor. I cant figure it out. It will start after the battery is unhooked sometimes and runs for a a bit this shuts off. Any advice?
Feral
Earth
The crank position sensor on my 93 4.0 is on the bell housing behind the engine. Its not too hard to get at.
I would replace the coil as well.
jeepjoe43
Lifetime Supporting Member
Black Canyon City, AZ 85324
I agree with Feral, but would add inspect the wires to the connectors, too.
Back in the 80s & 90s Chrysler was sacrificing quality for weight due to CAFE regs.
My gremlin was a stressed/broken wire on the plug to the coil, cheap wire.
As I understand it, a CPS failure usually manifests when it gets hot, but don't rule it out.
J
Jharp59
Oklahoma
Thank you all. Changed coil, same problem. Ordered a new Ignition Control Module. I’ll update as appropriate
