1989 YJ 2.5 starts when cold but has trouble starting once warmed up
Kingdotkom
TN
I have a 1989 YJ Wrangler 2.5L 4cyl with EFI.
The problem is it starts fine when cold, but after you drive it for a while and then shut the engine off, it will not start. You crank it over and over with no start. After it sits and cools down for several hours it will start again. Please help with what might be causing this issue? Thanks Joe!
