I've got a 2.5" lift on an '89 and had the rear drive shaft break out of the brackets on the rear pinion yoke.
There's a bolt sheered off in the yoke so I'm replacing it. The stock drive shaft also got damaged as it flopped around when it came loose so, since I have to replace it anyway, I'm going to go ahead and get an SYE kit and a driveshaft from Adams.
My question is, I have metal rails that are maybe 1.5" high that were installed between the skid plate and the frame - they were there when I got the Jeep - this is a transfer case dropdown, correct?
When I install the SYE and the CV driveshaft, do I get rid of those rails and just bolt the skidplate directly to the frame? Do I need to get shorter bolts if so?
I see a lot of other YJs with rubber grommets up between the frame and the skidplate, is that just a different type of transfer case dropdown? Or are they there so you can get the mud and dirt that gets up in there out more easily?
